5 members (ShopRag, Phak1, Bill Hanlon, Otto Skorzeny, 3B), 116 guests, and 4 robots.
Topics128,034
Posts1,055,547
Members48,425
#785725 10/03/2011 5:03 PM
burr on plug thread in head, what thread are they? THANKS!
http://www.6066gmcguy.org/partnumbers.htm list the plug as an AC Delco AC4. AC Delco catalog says 14mm.
Putting 1966 GMC 1000 305V6 into www.napaonline.com gets a Champion CHA 405 plug with 14mm threads.
I have access to a couple of these motors but am not where I can get to one right now to give you anything more definitive than this googling.
Edit: One more thing, you probably will get more information on this motor in the 60-66 subforum than in this engine section here at Stovebolt.com, just my take on it.
R-Bo
1966 GMC 305V6 in the family
hhhmmm strange it's metric! I have a spare motor, but this ones rebuilt like new! I'll give the tap a try on the spare. Was putting the plug in, but it wouldn't catch. Thats when I climbed up and looked over and saw the split washer laying over the plug hole!!!! Thank god it wasn't small enough to drop in.
One thing about those V6's is that a lot of junk falls into the spark plug holes with them being on top of the motor. Glad you found your problem was an easy fix.
I had never thought about it so I also was surprised plug threads were metric. I did some research:
Spark plugs were NPT threads on Model T's, but in the 1930's manufacturers started using metric (14MM and 18MM) threads. Evidently Ford switched from NPT to metric on flathead motors in the 30's. So early flatheads are different from most of them.
From what I have heard it had something to do with Albert Champion moving from France to Flint, Michigan to start Champion spark plugs and AC spark plug companies. Being european, he would use metric threads.
http://www.smokstak.com/forum/showthread.php?p=350782
Also I found that the best way to deal with this is not with a tap but with a thread chaser, Summit Racing, et cetera, sell specific tools for this with 14mm on one end and 18mm on the other.
(Now when you get to screw-on oil filters, some are metric threaded and some are SAE standard threaded, and--don't assume all Japanese stuff is metric. Mazda's are metric and Toyotas and Kawasaki air cooled motors are standard. Go figure...)
Did you do the rebuild on your motor? My son has a running motor with about 95K original miles, and found a spare that we are planning to rebuild and it seems pistons and main bearings are hard to find. Those things are made like anvils. My engine stand groaned when we loaded that big boy on it.
R-Bo
thanks, ordered a thread chaser on ebay for 8 bucks including shipping. went in nice and smooth. plug went in smooth too. dodged another bullet!!!! THANKS!!!!!!!!!!!!!!
see alot of motor stuff on ebay. I search GMC 196* so i get the later 305 stuff too.
