1 members (Hotrod Lincoln), 61 guests, and 2 robots.
Topics128,049
Posts1,055,740
#775774 08/28/2011 3:45 PM
Looking to keep the original look . My truck is a 1952 6400 2 Ton 161 WB Are they door or cab mounted just the left or did they have the right mirror? thumbs_up
thanks
Jay
Mine just had the cab mount on the Driver side. Used two brackets on the cab that the bar of the mirror bolted in between. Look neet, but wobble on these big trucks. I believe the Passenger side mirrors were the same, but a factory option/accessory.
1949 1.5 Ton 4400, 1969 c10, 1989 c1500, 1990 K2500, 2010 C1500 Crew
They are mounted on the cowl from the factory. They have a support plate behind the sheetmetal that supports them.
Thanks for the reply
