| | | Forums66 Topics128,052 Posts1,055,718 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2011 Posts: 64 'Bolter | | 'Bolter Joined: May 2011 Posts: 64 | Looking to keep the original look . My truck is a 1952 6400 2 Ton 161 WB Are they door or cab mounted just the left or did they have the right mirror?  thanks Jay | | | | | Joined: Jan 2011 Posts: 32 New Guy | | New Guy Joined: Jan 2011 Posts: 32 | Mine just had the cab mount on the Driver side. Used two brackets on the cab that the bar of the mirror bolted in between. Look neet, but wobble on these big trucks. I believe the Passenger side mirrors were the same, but a factory option/accessory.
1949 1.5 Ton 4400, 1969 c10, 1989 c1500, 1990 K2500, 2010 C1500 Crew
| | | | | Joined: Nov 2006 Posts: 2,544 Shop Shark | | Shop Shark Joined: Nov 2006 Posts: 2,544 | They are mounted on the cowl from the factory. They have a support plate behind the sheetmetal that supports them. | | | | | Joined: May 2011 Posts: 64 'Bolter | | 'Bolter Joined: May 2011 Posts: 64 | | | |
