4 members (1955 1 Series, Barney1951, Otto Skorzeny, 1 invisible), 44 guests, and 2 robots.
Topics128,032
Posts1,055,438
Members48,422
I'm confused about what front motor mounts to use on a V8 in my 55 2nd 6100. The ones that are sold by the vendors and listed as V8 arethese 2 1/2" between washers. The 55 shop manual showsthese 1" between washersfor a V8 andthe 2 1/2" between washersfor a 6 cylinder. I have the taller ones in my truck herebut I have a firewall clearance problem with my valve covers. I tried the short mounts and they solve the valve cover problem but they don't line up with the motor brackets(no photo sorry). I'm thinking of modifying the brackets to 1 3/8" between washers. That would solve the valve cover problem and I think they will line up properly . Has anyone ever run into this before? Thanks!
1955 Chevrolet 6100 Wrecker
More pix on Flickr
"A good mechanic doesn't know everything, but he can figure out anything". ~ --My DAD
1955 Chevrolet 6100 Wrecker Video
1955 Chevy 6100 Wrecker Update Video
that shop manual pic is misleading, note the offset jog in the middle of the pin where they "photochopped" it .... mounting the front that low would give problems with misalignment stresses on the rear mounts and the trans angle to the front U-joint
what's the V8 you're trying to install? do you have the correct engine brackets? are they in the right place?
the mounts from the vendors are correct and work fine in any 56-58 I've put them in with 283's and 350's, there will be a problem with clearance for an HEI, but the stock valve covers shouldn't be touching
Thanks squeeze, I should have mentioned I have the tall valve covers. My motor is a 350 with roller rockers and rocker girdles. I should be able to make some modification and make it work with the correct front mounts. I have a small HEI dist. that will work. What application are the short motor mounts used for? Just curious.Thanks again. SEE YA! Mark
More pix on Flickr
cars
