7 members (NJC, David Bush, Oswald, Otto Skorzeny, GRNHydra, 2-Ton, Rusted Nut),
76
Mod | | | Forums66 Topics128,060 Posts1,055,838 Members48,427 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2006 Posts: 335 Shop Shark | | Shop Shark Joined: Sep 2006 Posts: 335 | they are two different lengths, which goes on which side? | | | | | Joined: Jun 2009 Posts: 2,201 Shop Shark | | Shop Shark Joined: Jun 2009 Posts: 2,201 | This is just a guess on my part. I would say the short one goes on the drivers side because you wouldn't want that door swinging too wide into street traffic. | | | | | Joined: Mar 2009 Posts: 788 'Bolter | | 'Bolter Joined: Mar 2009 Posts: 788 | Don;What back doors do you have; clamshell or barn door? ron must be clamshell; was just confused by other poster talking about the door swinging out I will see if I can check it out on mine for you
| | | | | Joined: Sep 2006 Posts: 335 Shop Shark | | Shop Shark Joined: Sep 2006 Posts: 335 | | | | | | Joined: Jun 2009 Posts: 2,201 Shop Shark | | Shop Shark Joined: Jun 2009 Posts: 2,201 | Don;What back doors do you have; clamshell or barn door? ron must be clamshell; was just confused by other poster talking about the door swinging out I will see if I can check it out on mine for you OK, I have and had several newer burbans and all had barn doors. sorry to confuse you guys. Just made an assumption that maybe the older burbs had metal where I have nylon straps. | | | | | Joined: Mar 2009 Posts: 788 'Bolter | | 'Bolter Joined: Mar 2009 Posts: 788 | short one goes to the passenger side. it should be obvious. ron | | |
