| | | Forums66 Topics128,095 Posts1,056,492 Members48,444 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2010 Posts: 304 Shop Shark | | Shop Shark Joined: Nov 2010 Posts: 304 | Bet these won't work on a '52 3100 would they? My notes say 185/75R16-215/85R16 tires are the best fit. Found two 235R60X16's in excell cond. for $40 but doesn't matter if they won't fit.
'52 3100 "once a Marine, always a Marine!! | | | | | Joined: Oct 2006 Posts: 843 Shop Shark | | Shop Shark Joined: Oct 2006 Posts: 843 | if you plan on putting them on the front,it would be a female dog to steer with stock steering.On the back with a 7" wide rim would look good I think
| | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | Those are going to be a very short tire, about the same size that you see on the FWD Impalas. The load capacity will also be very low, too low for a pickup.
Bill Burmeister | | |
