1 members (Samantha),
45
Mod | | | Forums66 Topics128,179 Posts1,057,159 Members48,465 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2008 Posts: 217 Shop Shark | | Shop Shark Joined: Feb 2008 Posts: 217 | Need to know if the dipsticks are the same. My 235 didn't have one so just wondering if I can swap the 216 to the 235. Thanks. Rick........ | | | | | Joined: Jan 2001 Posts: 5,337 'Bolter | | 'Bolter Joined: Jan 2001 Posts: 5,337 | As for a direct fit it, depends on the year.
See the USA in your vintage Chevrolet! My Blog | | | | | Joined: Jan 2000 Posts: 2,074 'Bolter | | 'Bolter Joined: Jan 2000 Posts: 2,074 | I'd say NO two different anamals, 235 would be much longer. | | | | | Joined: Mar 2011 Posts: 153 'Bolter | | 'Bolter Joined: Mar 2011 Posts: 153 |
1946 Chevy pickup, 1948 Chevy suburban, 1950 Chevy pickup, 1952 GMC pickup, 1957 Chevy pickup, 1939 Chevy pickup
| | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | As Dave posted, it depends upon the year, but, apparently, not on the engines within a given year (216s and 235s in the same years apparently used the same tube/stick): Making a blanket statement about 235 engines is misleading (and usually wrong): 235 engines were available from 1941-62 and had a variety of differences between 53 and 55. http://chevy.oldcarmanualproject.com/1929_57chevyparts/57cmpc0186.htm1.516: "gauge" rod lengths are shown separate from the tube lengths. Also, see the note at the bottom/end of that section (for trimming the stick/rod/"gauge"). | | |
