1 members (1 invisible),
46
Mod | | | Forums66 Topics128,043 Posts1,055,610 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2006 Posts: 693 'Bolter | | 'Bolter Joined: Jun 2006 Posts: 693 | my truck is away at the body shop, and i would like to know the dimensions of the ashtray if anyone has that handy or can take a quick measurement for me. i am thinking of using that space for gauge(s) | | | | | Joined: Jun 2011 Posts: 1,901 Shop Shark | | Shop Shark Joined: Jun 2011 Posts: 1,901 | ash tray. 4 7/8 x 1 3/8 x 3 1/2 dash hole 4 7/8 x 1 1/2
| | | | | Joined: Jun 2006 Posts: 693 'Bolter | | 'Bolter Joined: Jun 2006 Posts: 693 | thanks. i thought sure that the opening was wider than 1.5". this is for a '56 | | | | | Joined: Jul 2001 Posts: 3,887 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Jul 2001 Posts: 3,887 | Tom - mine is 2.5" wide and 5.25" high and the tray is very near exactly the same, a very snug fit
Bill | | | | | Joined: Jun 2006 Posts: 693 'Bolter | | 'Bolter Joined: Jun 2006 Posts: 693 | thanks for the reply Bill | | | | | Joined: Jun 2011 Posts: 1,901 Shop Shark | | Shop Shark Joined: Jun 2011 Posts: 1,901 | ash tray. 4 7/8 x 1 3/8 x 3 1/2 dash hole 4 7/8 x 1 1/2
I should have stated those numbers were from a 58 Jimmy my bad. I guess my heater switch is someone else ashtray.. ,
| | | | | Joined: Jul 2001 Posts: 3,887 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Jul 2001 Posts: 3,887 | ahh yes, I didn't think about you having a GMC - TF Chev dash, the heater switch delete also fits the ashtray hole  Bill | | | | | Joined: Jun 2011 Posts: 1,901 Shop Shark | | Shop Shark Joined: Jun 2011 Posts: 1,901 | ahh yes, I didn't think about you having a GMC - TF Chev dash, the heater switch delete also fits the ashtray hole  Bill Does that mean you still don't have an ashtray that would fit my rig?  I won't hold my breath Rick
| | | | | Joined: Jul 2001 Posts: 3,887 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Jul 2001 Posts: 3,887 | no, I had a GMC ashtray but can't find it, must have got passed on unnoticed
Bill | | | | | Joined: Jun 2006 Posts: 693 'Bolter | | 'Bolter Joined: Jun 2006 Posts: 693 | i finished my little ashtray -> tach project. i installed a tiny tach + hourmeter into a spare ashtray to leave the dash of my 56 unmolested and for easy return to OEM for showing. just need to tack the gauge flush to the ashtray with a little epoxy and pop the whole assembly in (then wire of course). i thought it came out pretty well. pic here: http://i1234.photobucket.com/albums/ff419/tomctomc/tinytach.jpg | | | | | Joined: Aug 2011 Posts: 687 Shop Shark | | Shop Shark Joined: Aug 2011 Posts: 687 | | | |
