3 members (panic, 2-Ton, 1 invisible), 133 guests, and 3 robots.
Topics128,260
Posts1,058,343
Members48,485
#7849 06/30/2003 7:56 PM
What (if any) external engine parts from a GMC 248 are interchangeable with a 302? Intake/carb? Head? This is my fist Task Force, thanks to all for being so patient and helpful!
#7850 07/01/2003 12:06 PM
Most everything you mention will "fit" but be careful, the 302 heads have bigger ports, different chambers and flat-top pistons. Some of the 248s used domed pistons, so swapping heads will give you a strangled 302 with very low compression. All of the external tinware can be used with no problem, as can water pump, damper pulley etc.
