0 members (),
41
7
Mod | | | Forums66 Topics128,077 Posts1,056,033 Members48,433 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2011 Posts: 8 New Guy | | New Guy Joined: Sep 2011 Posts: 8 | I just bought a '49 3/4 pickup with a later 235 engine. I don't know what the canister-type part is on the passenger side of the engine. It has a raised "X" on the top so I assume it comes off. Can anyone help me identify it? Thx. | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | We are flying blind and some people might try the WAG game; however, a photo or two would help a lot.
Road draft tube?
| | | | | Joined: Mar 2005 Posts: 1,636 'Bolter | | 'Bolter Joined: Mar 2005 Posts: 1,636 | My bet it is a road draft tube. | | | | | Joined: Sep 2011 Posts: 8 New Guy | | New Guy Joined: Sep 2011 Posts: 8 | OK, that must be it. Does it take a filter? Looks like the top piece might pop off. | | | | | Joined: Feb 2004 Posts: 29,792 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,792 | No, that piece is spot-welded together. Some of the older stovebolt engines had a twist-off oil filler cap on top of the road draft tube, but when they moved the oil fill to the top of the valve cover, the top of the road draft was sealed off.
They do have a nasty habit of getting clogged up with sludge. I used to remove the draft tube from the engine with a slide hammer, pour a few ounces of gasoline into it, and set it afire out behind the shop. The sludge would burn to ash, which could be flushed out with a garden hose or more solvent. Nowadays, that would get me all sorts of air pollution citations! Jerry
