2 members (Peggy M, panic),
89
Mod | | | Forums66 Topics128,030 Posts1,055,428 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2002 Posts: 384 Shop Shark | | Shop Shark Joined: Mar 2002 Posts: 384 | I seem to remember a California firm that manufactures fuel senders to original specifications. I bought a chinese one from the catalogues and it has now failed after about 5 years. It also would not read below 1/4 tank. I want to get a good, made in the usa one this time if possible. Please let me know if you know of a good one for my 55 first series 1/2 ton. Thanks - Scott
55 1st Chev.
| | | | | Joined: Sep 2011 Posts: 4 New Guy | | New Guy Joined: Sep 2011 Posts: 4 | I know there is one in Oregon, I had one made a couple of years ago. for my home made under the bed tank.. cost about $75. If interested let me know and I'll look up the address.. | | | | | Joined: Sep 2011 Posts: 4 New Guy | | New Guy Joined: Sep 2011 Posts: 4 | Oh i just had a thought, what kind do you need.. ???? I have an orginal 57 truck unit that was working when I removed it. and a couple of GM style units. Would not work with my VDO gages. They require a unit with some wierd numbers like 230 to 30 omes or something like that. Don't remember the correct number but you get the idea... LOL | | | | | Joined: Mar 2002 Posts: 384 Shop Shark | | Shop Shark Joined: Mar 2002 Posts: 384 | Thanks for the comment, Earlk6. I don't think I will have to go to a custom-made one tho. I am also hoping I will not have to get a used or foreign one. I can do 6 or 12 volt and I don't want the brights in the switch since I have a dimmer button on the firewall. I also don't need a perfect match.
55 1st Chev.
| | | | | Joined: May 2005 Posts: 1,624 Shop Shark | | Shop Shark Joined: May 2005 Posts: 1,624 | Finding the perfect ohm match for your gauge is as easy as puting a variable resistor between the sender lug on your gauge and ground. Finding a sender of the proper resistance made in the USA may prove much more difficult.
| | | | | Joined: Mar 2002 Posts: 384 Shop Shark | | Shop Shark Joined: Mar 2002 Posts: 384 | oops, I'm getting my 2 truck problems mixed up...talking about headlight switch when my thread is about the fuel gauge sending unit. Sorry Still looking for a fuel gauge sending unit usa. Scott
55 1st Chev.
