5 members (klhansen, 5 Window 9434, farmallb, Peggy M, 1 invisible), 59 guests, and 3 robots.
Topics128,024
Posts1,055,393
Members48,422
#784699 09/29/2011 4:13 PM
I seem to remember a California firm that manufactures fuel senders to original specifications. I bought a chinese one from the catalogues and it has now failed after about 5 years. It also would not read below 1/4 tank. I want to get a good, made in the usa one this time if possible. Please let me know if you know of a good one for my 55 first series 1/2 ton.
Thanks - Scott
55 1st Chev.
I know there is one in Oregon, I had one made a couple of years ago. for my home made under the bed tank.. cost about $75. If interested let me know and I'll look up the address..
Earlk6 #784915 09/30/2011 5:16 AM
Oh i just had a thought, what kind do you need.. ???? I have an orginal 57 truck unit that was working when I removed it. and a couple of GM style units. Would not work with my VDO gages. They require a unit with some wierd numbers like 230 to 30 omes or something like that. Don't remember the correct number but you get the idea... LOL
Earlk6 #785020 09/30/2011 5:43 PM
Thanks for the comment, Earlk6. I don't think I will have to go to a custom-made one tho. I am also hoping I will not have to get a used or foreign one. I can do 6 or 12 volt and I don't want the brights in the switch since I have a dimmer button on the firewall. I also don't need a perfect match.
55 1st Chev.
Finding the perfect ohm match for your gauge is as easy as puting a variable resistor between the sender lug on your gauge and ground. Finding a sender of the proper resistance made in the USA may prove much more difficult.
beltfed #785764 10/03/2011 7:30 PM
oops, I'm getting my 2 truck problems mixed up...talking about headlight switch when my thread is about the fuel gauge sending unit. Sorry Still looking for a fuel gauge sending unit usa.
Scott
55 1st Chev.
