0 members (), 35 guests, and 3 robots.
Topics128,014
Posts1,055,327
Members48,419
#784886 09/30/2011 3:16 AM
I have motor which has a 235 head from '59 Apache and a 250 block from some other vehicle. Will that 250 block match up with '51 GMC 3-speed manual transmission?
You would need a bellhousing from a '55-'72 V8 or a '63-'72 6, plus a few chassis modifications, to make it work with the stock transmission.
You'll need to get the correct head in order to use the 250 block, the 235 head will not work with the 250 block.
Bill Burmeister
