2 members (Otto Skorzeny, Phak1), 132 guests, and 4 robots.
Topics128,272
Posts1,058,319
Members48,485
#784732 09/29/2011 6:51 PM
Hi guys,
for my '59 1/2T project, I have some door bottom issues and one front fender support issue.
I've seen through "classic parts" that I can buy sections to repair these.
I was just daydreaming at work about these and was wondering if the skins are welded and crimped or just crimped.
I'm trying to get an idea of the tools and skill type required.
Thanks!
the door skins are spot welded after crimping ["pinch weld"], the brace behind the rear of the fender 'floats', welded at the top and bottom .... requires metal working skills, good die grinder for cutting and fitting, welder, patience
squeeze #784744 09/29/2011 7:27 PM
Thanks for the reply, Bill.
Maybe then, I'll just buy the sections I need and find an experienced service to handle the rest.
Ex Hall Monitor
Ex Hall Monitor
That would be the wise thing to do. You can do some serious damage to a brand new skin folding the edge over if you don't do it right.
Tiny #785218 10/01/2011 6:36 AM
who sells these door skins, as I will need them also for my 36 Suburban. Does some co. make asteel floor pan for the cab in trucks, my floor is gone..it could be replaced in wood or steel?
1936 Chevy Suburban Carryall
1941 Chevy Woodie with Cantrell body
1936 Low Cab Chevy Pickup
1941 Spec Deluxe Chevy Coupe.
1953 Pontiac Catalina hardtop
More pix on Flickr
mtvoices #785307 10/01/2011 8:44 PM
American Classic Truck Parts
Jim Carter Truck Parts
My two favorite vendors. Click the links & it will take you right to the door panels. You can only buy a section of the panel.
OPS, sorry. I did 55-59 panels, Jim Carter has the outer section, American Classic only has the inner.
1957 Chevrolet 1/2-ton Stepside LB in the Gallery
My Photobucket shots
The person who has nothing for which he is willing to fight, nothing which is more important than his own personal safety, is a miserable creature and has no chance of being free unless made and kept so by the exertions of better men than himself." - John Stuart Mill (1806 - 1873)
