8 members (JW51, Woodcmiami, Gdads51, dt235sd, MickeyP, HandyAndy, k2handyman, 1 invisible), 58 guests, and 1 robot.
Topics128,049
Posts1,055,699
#784553 09/28/2011 11:59 PM
V
V Offline
Well we have determined the heater core leaks at the valve that controls the temperature. What is that valve called and can I purchase a new/rebuilt one. I tried the search feature and come up with very little info, so any thing someone might add would be greatly appreciated.
Jessica's Truck
The true definition of insanity:
To do the same thing the same way repeatedly and expect a different result each time.
called a Ranco valve, American Classic has them [$89], but for my money, a remote cable controlled valve that mounts inline on a heater hose under the hood is less headache long term and cheaper, found at your FLAPS
V
V Offline
Squeeze,
Thanks for the reply. I like the idea of the aux valve under the hood, but after removing the leaking valve there is no longer a copper tube through the firewall to connect to the heater hose. do you have a suggestion for the plumbing aspect as well.
Jessica's Truck
you might add some copper plumbing pipe to extend it, or find some rubber hose to fit, or cut the tubes off the old Ranco and solder a patch on like these that I've found in a couple heaters from trucks I've parted [one 1/2", one 5/8"]
Ya if you dont want to use a valve in the heater box you must have some copper put on. I tryed for days to get the rubber hose to work and it was not working. Just to sharp of turns for it to make without kinking.
1959 Chevy Apache 3100/ 283 TBI / 4L60E
My YouTube:
https://www.youtube.com/mikebtte
V
V Offline
I talked with both vendors (American Classic and classic parts)and the only heater control valve they offer has a 5/8" inlet and a 5/8 outlet. The ones in my heater core are 3/4" therefore to use these i would need to reduce it inside the heater box and I do not believe there is enough room for that. Curious if someone might have had the same trouble. otherwise I believe Squeeze might have he answer that will be the least headache.
Jessica's Truck
