1 members (baldeagle),
36
Mod | | | Forums66 Topics128,014 Posts1,055,327 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2010 Posts: 127 Wrench Fetcher | | Wrench Fetcher Joined: Jul 2010 Posts: 127 | Well we have determined the heater core leaks at the valve that controls the temperature. What is that valve called and can I purchase a new/rebuilt one. I tried the search feature and come up with very little info, so any thing someone might add would be greatly appreciated. Jessica's TruckThe true definition of insanity: To do the same thing the same way repeatedly and expect a different result each time. | | | | | Joined: Jul 2001 Posts: 3,887 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Jul 2001 Posts: 3,887 | called a Ranco valve, American Classic has them [$89], but for my money, a remote cable controlled valve that mounts inline on a heater hose under the hood is less headache long term and cheaper, found at your FLAPS Bill | | | | | Joined: Jul 2010 Posts: 127 Wrench Fetcher | | Wrench Fetcher Joined: Jul 2010 Posts: 127 | Squeeze, Thanks for the reply. I like the idea of the aux valve under the hood, but after removing the leaking valve there is no longer a copper tube through the firewall to connect to the heater hose. do you have a suggestion for the plumbing aspect as well. Jessica's TruckThe true definition of insanity: To do the same thing the same way repeatedly and expect a different result each time. | | | | | Joined: Jul 2001 Posts: 3,887 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Jul 2001 Posts: 3,887 | you might add some copper plumbing pipe to extend it, or find some rubber hose to fit, or cut the tubes off the old Ranco and solder a patch on like these that I've found in a couple heaters from trucks I've parted [one 1/2", one 5/8"] Bill | | | | | Joined: Sep 2010 Posts: 166 Shop Shark | | Shop Shark Joined: Sep 2010 Posts: 166 | | | | | | Joined: Dec 2010 Posts: 291 Shop Shark | | Shop Shark Joined: Dec 2010 Posts: 291 | Ya if you dont want to use a valve in the heater box you must have some copper put on. I tryed for days to get the rubber hose to work and it was not working. Just to sharp of turns for it to make without kinking. | | | | | Joined: Jul 2010 Posts: 127 Wrench Fetcher | | Wrench Fetcher Joined: Jul 2010 Posts: 127 | I talked with both vendors (American Classic and classic parts)and the only heater control valve they offer has a 5/8" inlet and a 5/8 outlet. The ones in my heater core are 3/4" therefore to use these i would need to reduce it inside the heater box and I do not believe there is enough room for that. Curious if someone might have had the same trouble. otherwise I believe Squeeze might have he answer that will be the least headache. Jessica's TruckThe true definition of insanity: To do the same thing the same way repeatedly and expect a different result each time. | | |
