| | | Forums66 Topics128,091 Posts1,056,038 Members48,433 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2011 Posts: 687 Shop Shark | | Shop Shark Joined: Aug 2011 Posts: 687 | I'm going to have the drive shaft (or torque tube??) out of my 1950 3600 Chevy. While it's out, I want to fix some small leaks at the rear of the transmission and the center u-joint. Can someone tell me if there are seals in there and if NAPA carries them? I can't find them on the LMC site.
Thank you. | | | | | Joined: Aug 2011 Posts: 835 Shop Shark | | Shop Shark Joined: Aug 2011 Posts: 835 | | | | | | Joined: Aug 2011 Posts: 687 Shop Shark | | Shop Shark Joined: Aug 2011 Posts: 687 | Thanks Kurt. I've never ordered from Jim Carter, but heard good things about them. I ordered what I needed so we'll see what happens. The thow out bearing is making noise (and it's new) so I have a feeling the previous owner that had someone put it in, used the wrong one. I orderded the one that is 1 7/8" long. I think they used the later one that is only 1 1/5" long. We'll see. Thanks. | | | | | Joined: Aug 2010 Posts: 368 Shop Shark | | Shop Shark Joined: Aug 2010 Posts: 368 | Hey Guys, I have a 54 3100...4 speed sm420, I have a leak directly behind my tranny at the enclosed tube. I'm assuming thats the U-Joint. I looked at the link above for the Gaskets and seals....Why is there 2 sets of 4 gaskets that are the same? Nothing else is leaaking except that connection. I re-tightened the bolts(they were loose),but when I stop she dribbles...bothers me to no end.
| | | | | Joined: Aug 2011 Posts: 835 Shop Shark | | Shop Shark Joined: Aug 2011 Posts: 835 | Jimmi,
I believe the multiple gaskets are used so you can shim the cover so that the ball part of the joint at the end of the torque tube will be neither too loose nor too tight. I am guessing that there are two different gasket designs because there are two different cover designs.
Mine takes the four bolt gasket. I have the four speed in a 1951 1/2 ton.
Does sound like your seal is shot.
Kurt | | | | | Joined: Sep 2006 Posts: 3,596 'Bolter | | 'Bolter Joined: Sep 2006 Posts: 3,596 | | | |
