4 members (32Fordpuchoptop, 55shaker, TUTS 59, 1 invisible), 70 guests, and 0 robots.
Topics128,078
Posts1,055,940
Members48,430
#78444 06/05/2007 3:28 PM
A friend of mine who is a collector of scrap metal has come up with a bunch of bearings, most of them used, but this one Fafnir 207k is still in plastic cover, never used, And on the outer race it has GM3110-144-8534 12/59. My question , Is there a way to ID the application of this bearing, Im thinking trans bearing. But i thought i would come to the Stovebolt Brain Trust for help ohwell
#78445 06/05/2007 3:42 PM
T-RUCK,
The 6207 is a common metric bearing. 35mm X 72mm X 17mm wide. Retails for about $10.00 anywhere. The numbers marked on the race sure seem like some GM number, but I haven't a clue if they are or where this bearing would go! For ten bucks, I wouldn't put much energy into it. smile
I wonder if your bearing has external snap ring grooves?
Stuart
#78446 06/05/2007 4:07 PM
The 6207 is the front bearing on a 55-67 3 speed transmission installed on the clutch gear. It probably fits earlier transmissions also.
Fred
#78447 06/05/2007 4:15 PM
Thanks Stuart. Yea the race is what got me going on it , But if it's a replacement for something i have what the heck, i'll keep it floting around for a few weeks [ marked unknown]
#78448 06/05/2007 4:20 PM
Boy that should give you guy an idea how slow im at typeing, [now it is known] to be 3 speed trans input shaft bearing Thanks Fred smile
