9 members (treegrower, 68ironhead, GRNHydra, Nhluvstruck, 55shaker, MickeyP, elhippie64, David Bush, 1 invisible),
43
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,090 Posts1,056,016 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#78444 06/05/2007 3:28 PM | Joined: Feb 2002 Posts: 121 Shop Shark | | Shop Shark Joined: Feb 2002 Posts: 121 | A friend of mine who is a collector of scrap metal has come up with a bunch of bearings, most of them used, but this one Fafnir 207k is still in plastic cover, never used, And on the outer race it has GM3110-144-8534 12/59. My question , Is there a way to ID the application of this bearing, Im thinking trans bearing. But i thought i would come to the Stovebolt Brain Trust for help  | | |
#78445 06/05/2007 3:42 PM | Joined: Jul 2004 Posts: 5,708 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 5,708 | T-RUCK, The 6207 is a common metric bearing. 35mm X 72mm X 17mm wide. Retails for about $10.00 anywhere. The numbers marked on the race sure seem like some GM number, but I haven't a clue if they are or where this bearing would go! For ten bucks, I wouldn't put much energy into it. I wonder if your bearing has external snap ring grooves? Stuart | | |
#78446 06/05/2007 4:07 PM | Joined: Apr 2005 Posts: 2,097 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 2,097 | The 6207 is the front bearing on a 55-67 3 speed transmission installed on the clutch gear. It probably fits earlier transmissions also. Fred
#78447 06/05/2007 4:15 PM | Joined: Feb 2002 Posts: 121 Shop Shark | | Shop Shark Joined: Feb 2002 Posts: 121 | Thanks Stuart. Yea the race is what got me going on it , But if it's a replacement for something i have what the heck, i'll keep it floting around for a few weeks [ marked unknown] | | |
#78448 06/05/2007 4:20 PM | Joined: Feb 2002 Posts: 121 Shop Shark | | Shop Shark Joined: Feb 2002 Posts: 121 | Boy that should give you guy an idea how slow im at typeing, [now it is known] to be 3 speed trans input shaft bearing Thanks Fred  | | |
