1 members (69Cuda),
83
Mod | | | Forums66 Topics128,096 Posts1,056,487 Members48,444 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2006 Posts: 4,983 Master Gabster | | Master Gabster Joined: Oct 2006 Posts: 4,983 | 1/2 inch lower than the left side. It seems to the frame that is the trouble not the bed. It's a TCI spring kit back there. Will I need to shim the right side up or is there something I'm missing?
~Jim
| | | | | Joined: Dec 2008 Posts: 319 Shop Shark | | Shop Shark Joined: Dec 2008 Posts: 319 | What are you measuring that tells you one side is lower than the other? Bumper? Wheel wells? Axle centerline? Frame rail ends? Underside of bed floor? Rocker panels? And why do you think it's the frame?
cm If you can't fix it with a hammer and screwdriver, you need a bigger hammer.1965 Chevy C10 | | | | | Joined: Oct 2006 Posts: 4,983 Master Gabster | | Master Gabster Joined: Oct 2006 Posts: 4,983 | I first measured at the top of the tailgate then the end of the frame rails, axles and the bottom of the fuel cell. Here are some pics. TILT 1 TILT 2
~Jim
