0 members (), 108 guests, and 0 robots.
Topics128,115
Posts1,056,292
Members48,439
#784341 09/28/2011 4:40 AM
1/2 inch lower than the left side. It seems to the frame that is the trouble not the bed.
It's a TCI spring kit back there. Will I need to shim the right side up or is there something I'm missing?
~Jim
What are you measuring that tells you one side is lower than the other? Bumper? Wheel wells? Axle centerline? Frame rail ends? Underside of bed floor? Rocker panels?
And why do you think it's the frame?
cm
If you can't fix it with a hammer and screwdriver, you need a bigger hammer.
1965 Chevy C10
I first measured at the top of the tailgate then the end of the frame rails, axles and the bottom of the fuel cell.
Here are some pics.
TILT 1
TILT 2
~Jim
