4 members (baldeagle, NorCal52Suburban, DaveV, Opelika Tom), 85 guests, and 1 robot.
Topics128,037
Posts1,055,470
Members48,424
#78414 06/04/2007 3:32 PM
Apprentice
Apprentice
I am putting a t-5 trans in my 67 Chevy. The only ones I have been able to find are electric speedos. I have read and checked into the different conversion kits and don't want to spend the money on them. Does anyone know of a place that makes adapter busings to put mec speedo in it? Pleas help!!
MACZ
Riding in the Passing Lane
You need the tail housing & the gear that goes on the shaft, & the gear & holder for the speedo cable off a 87 & earlier T-5 or T-4.
1972 Chevy c10 Cheyenne Super
Apprentice
Apprentice
Wrenchbender,
Do you know where I can get the tail housing? I have the rest of the parts from a Z28. The s-10 t-5 I got has electric and wont work. Any help would be great.
MACZ
#78417 06/04/2007 10:39 PM
One of the pull your own parts type salvage yards is good. Try posting in parts wanted in the swap meet section of this websight.
You may want the s-10 tail section for another reason: It comes with a shifter box that is close to the main case as opposed to at the far end of the tail shaft. In the AD trucks if you use the z-28 tail shaft you'll end up with your shifter under your seat, or very close to it, I don't know if that is the same with your 67, but its worth thinking about.
When I was researching switching to a t-5 in my '51 I read a posting that talked about using a World Class T-5 box, which has nicer bearings a better gear ratios (like the z-28 tranny), and the tail shaft from an earlier one for the two reasons you need to do it: speedo gear and shifter box. The posting even has pictures! Try the 'search' function on this site and inliners for the t-5 conversion and read some of the articles in 2005, like this one:
http://www.inliners.org/Jack/T5tech.html
Here's another website with info and a source for T-5 parts:
http://www.5speeds.com/t5/
