7 members (Bill Trotter, mick53, GIJOE298, Mike'sPlace, Otto Skorzeny, Hush, 1 invisible),
77
Mod | | | Forums66 Topics128,080 Posts1,056,288 Members48,441 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2010 Posts: 202 'Bolter | | 'Bolter Joined: Oct 2010 Posts: 202 | Evening all
Is there a way to mount a backup switch on a 1954 SM420 4speed transmission? I thought it would be a nice feature to add to my 3100.
Thanks in advance Walt L. Williams La Verkin, Ut. | | | | | Joined: Nov 2006 Posts: 247 'Bolter | | 'Bolter Joined: Nov 2006 Posts: 247 | Walt The 1955 Cameo's had a switch close to the top of the transmission tower on the left side inside in the cab with a little arm welded to the gear shift stick. When you would pull it to the left and down to go to reverse it would push the button on the switch. I haven't seen one for years. It seemed to work pretty well Jim | | | | | Joined: Jan 2002 Posts: 2,254 'Bolter | | 'Bolter Joined: Jan 2002 Posts: 2,254 | I have a cap (replacement for the cap that holds the shifter shaft in) that holds a switch on the top of my transmission. And a lever on the shifter shaft that pushes down on the switch when I shift into reverse to turn on the reverse lights. This came in the kit I bought many years ago and previously used the other setup on a column three speed in a 55 2nd.
Dennis -there is nothing stronger than the heart of a volunteer-
| | | | | Joined: Nov 2002 Posts: 1,002 Shop Shark | | Shop Shark Joined: Nov 2002 Posts: 1,002 | IIRC there have been several discussions on this in the last 2-3 years, and there are kits still available. The backup light switch was an option on the 67 (last year for SM420), and possibly earlier trucks. I can't remember any particular poster to help narrow a search.
Larry
I don't own a vehicle that isn't old enough to drink. | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | | | | | | Joined: Nov 2004 Posts: 1,552 Shop Shark | | Shop Shark Joined: Nov 2004 Posts: 1,552 | They were also found on the '60-'66 Chevy trucks, but standard equipment in 1966. Reverse light switch | | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | Dennis, think you could post a couple of pictures of that cap and switch and is it the same one that Tim linked us to at JC‘s site?
Larry, please tell us where the kits are still available at??
Tony, do you know if those were the clip on switches like those pictured above or did the covers have the casting for the internal switch???
And lastly, what would the backup light itself from the GM accessory kit have looked like???? Denny Graham Sandwich, IL
Denny G Sandwich, IL
| | | | | Joined: Jan 2002 Posts: 2,841 'Bolter | | 'Bolter Joined: Jan 2002 Posts: 2,841 | Too bad I didn't know of those switches back when I did mine. My method is a lot of work, but it was a fun winter project. http://rides.webshots.com/album/141689703NurJLp
Craig My '50 Chevy 3100 5 window, '62-235cu, 3:55 rear My truck ....... Respect The Rust If I'm not working on my truck, '65 m00stang or VW camper, I'm fishing with the wife or smoking Salmon.
| | | | | Joined: Sep 2006 Posts: 3,596 'Bolter | | 'Bolter Joined: Sep 2006 Posts: 3,596 | | | | | | Joined: Jan 2002 Posts: 2,254 'Bolter | | 'Bolter Joined: Jan 2002 Posts: 2,254 | Yup. That is the setup I have. I need to figure out what kind of lights to use.
| | | | | Joined: Nov 2002 Posts: 1,002 Shop Shark | | Shop Shark Joined: Nov 2002 Posts: 1,002 | "Larry, please tell us where the kits are still available at??" Denny, I never followed up on getting a kit. The thread may have been more than 2-3 years ago. I did a search to see if I could find the thread, but ran into a problem. Some of the links from the search results would only get me to the Forum, not the post. Such as the following, Hedgehog had a link to pictures. (the following link appears to have a problem(?), but I could cut and paste to get it to come up) https://www.stovebolt.com/ubbthreads/ubbthreads.php?ubb=showflat&Number=22485&Searchpage=3&Main=3640&Words=%2Bbackup%2Bswitch%2Bkit&Search=true#Post22485 This is a good link to a picture of the original pieces I believe Squeeze made the link; http://carphotos.cardomain.com/ride_images/2/2877/4121/19692060221_large.jpgI seem to remember there was a picture of the kit and it reversed the above setup. The switch(brake?) was clamped to the shifter, and,,, I don't remember how the stop for the switch was mounted. Larry
I don't own a vehicle that isn't old enough to drink. | | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | You must have posted before Craig, I remember looking thru your web shots and downloading them for future reference. You’ve come up with a good solution, it looks very professional and looks like it belongs on the transmission. Looks like it clears but might be kinda close to the cover. To bad we couldn’t find one with a smaller thread diameter so you could move it down a few degrees, it wouldn’t take much to give it plenty of clearance. But I really do like it. By the way, where did you find the backup lights??
Tks but that looks like the GM accessory switch that JC has posted on his tech tips page.
| | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | Denny, For back-up lights on my 54 1/2 ton Hydra-Matic (that has a back-up light switch), I am going to try to attach a backup lamp to each of the two 54 tail lights. I have obtained a NOS pair of black back-up lamps like the one shown on the Suburban tail lamp in this JC article. The other backup lamps that I will be mocking up are used GUIDE B-31 lamps that I will paint black (if I use them). | | | | | Joined: Oct 2010 Posts: 202 'Bolter | | 'Bolter Joined: Oct 2010 Posts: 202 | Thanks for the info. I didn't expect so many responses. I will see if I can implement a small arm on my shifter and position a switch on the top of my transmission..... unless someone knows of a kit that I can purchase.
Walt Williams La Verkin, UT | | |
