| | | Forums66 Topics128,047 Posts1,055,532 Members48,424 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2006 Posts: 4,983 Master Gabster | | Master Gabster Joined: Oct 2006 Posts: 4,983 | I bought a set of SS conduit for the rear tail lights. Now I need to know how to attach them to the tail lights. There are no apparent ends for attaching on them so what gives... Conduit 1 Conduit 2 Conduit 3
~Jim
| | | | | Joined: Jul 2001 Posts: 3,887 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Jul 2001 Posts: 3,887 | your tail lights weren't created for conduits, you need some magic  Bill | | | | | Joined: Oct 2006 Posts: 4,983 Master Gabster | | Master Gabster Joined: Oct 2006 Posts: 4,983 | That I can manage. Thanks Bill.
~Jim
| | | | | Joined: Feb 2004 Posts: 29,756 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,756 | Squirt the end of the conduit full of clear RTV just before you slip it all the way onto the rubber grommet at the back of the light, then tie a knot in the wires at the other end to hold the conduit tight against the back of the tail light. When the RTV hardens, you'll have a semi-permanent installation of the conduit over the wires. If you ever need to remove it, use a heat gun on the outside of the conduit to soften the RTV. Jerry
| | | | | Joined: Oct 2006 Posts: 4,983 Master Gabster | | Master Gabster Joined: Oct 2006 Posts: 4,983 | Thanks Jerry, I'll try that.
~Jim
