Brrrr
Winter is Coming
A good Tech Tip
WINTERIZING YOUR TRUCK
7 members (1955 1 Series, 3B, Jay R, Wayne67vert, Phak1, DaveV, Hush), 123 guests, and 2 robots.
Topics128,274
Posts1,058,433
Members48,490
#783969 09/27/2011 2:25 AM
Hi I have a 52 Chevy 3600 I have restored.I am trying to figure out how to hook up the throttle cable to the Rochester carb.When I hook it up I run the cable through the accelerator linkage and put a cable stop on it.The problem is when I pull the throttle I am pulling against the stiff return spring.I am at a loss.
You have it hooked up right.
Push the gas pedal down with your foot while pulling the throttle cable, much easier! Then you can take your foot off the gas pedal and it will stay put.
When I let off the gas it wants to pull the cable back in.
maybe your throttle return spring is too strong or your cable doesn't have enough resistance, they do get worn
Its a new cable and an old spring.I will look into the spring tension though.
Joy Offline
bump
Do you have the special little bracket that mounts on the carb and the 2 cables pass thru it? (choke and throttle cables)
You must have that or it wont work.
PM me your e-mail address if you need a picture.
Yes I do.After further research I beleive I have a different spring than original.
