9 members (TUTS 59, Millenimech, cmayna, Hanks custodian, Otto Skorzeny, Oswald, Cosmo, Bill Hanlon, gswbbc),
89
Mod | | | Forums66 Topics128,042 Posts1,055,522 Members48,424 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2011 Posts: 7 New Guy | | New Guy Joined: May 2011 Posts: 7 | Hi I have a 52 Chevy 3600 that I have restored.I am trying to figure out how to hook up the throttle cable to the Rochester carb.I run thre cable through the accelerator linkage and put a cable stop on the end.The problem is when i pull the throttle I am pulling against the stiff return spring.Any help is appreciated. | | | | | Joined: Jan 2001 Posts: 5,337 'Bolter | | 'Bolter Joined: Jan 2001 Posts: 5,337 | Sounds like you have it hooked up right, maybe you need a softer spring.
See the USA in your vintage Chevrolet! My Blog | | |
