2 members (Peggy M, Ponchogl), 52 guests, and 6 robots.
Topics128,021
Posts1,055,355
Members48,420
#783740 09/26/2011 5:11 AM
Having trouble reassembling my headlamps on my 54 1/2 ton PU... The shop manual pages 12-38/39 are not much help and the Truck Assembly Manual sec.12 sheet 1.04 is not detailed enough... Does any one have some good pics on how these go together ? Mine were taken apart 20 years ago...
Here are the Parts that I have, I have the headlights too...
According to the Shpo Manual Pic looks like I am missing one Headlamp Adjusting Screw and one spring ( " E " ) in the pic... I do not ever remember having two springs nor can find them... I looked at my lamp housing and it does not look like there is a place for another spring...
According to CPA there are no Headlamp Adjusting Nuts for truck years 1947-1957 so I am having trouble understanding how they fit in...
Pics would be great...
Thanks in advance...
1954 Chevy 3104 3 Window Hydra-Matic in my family for over 60 Years
Once in a while you get shown the light in the strangest of places if you look at it right... "Scarlet Begonias" Grateful Dead 1974
cars are the same those years
dan-pa
dan-pa #783793 09/26/2011 2:12 PM
...spring...
Its hard to tell from your photobucket pics but it looks like your spring is missing some coils.
I picked up a spare headlamp housing by placing an add in the parts wanted section of the forum.
DADS50 #783856 09/26/2011 7:31 PM
Thanks Denny & DADS50 for your pics...
I am missing the flat nuts for the Headlamp Adjusting Nuts... That what through me off... This is what Classic Parts said about not having Headlamp Adjusting Nuts for 1947-1957 see their Detailed Description ...
DADS50 my coil spring is intact with no missing coils... Pic was taken straight on so it is a little hard to see...
American Classics sells the adjustment nuts
...link...
part number HLSBA41-4
American Classic has the headlight adjustment screw and nut comments totally wrong. On my '52 Chevy 3100, each headlight has two screws AND two nuts. The nuts would be easy to replicate with aluminum stock of equal thickness, cut to shape, drilled and tapped. Aluminum just for ease of fabrication.
DavidF #784448 09/28/2011 4:50 PM
David - American Classic sells the correct parts, it's Classic Parts that has the wrong info
and there's a good reason plastic was used, aluminum nuts with steel screws and steel stanchions would be a recipe for future corrosion problems
healingbear - your single spring is correct and your buckets are as they should be, just need those adjuster nuts
Thanks Bill...I figured that out and I have a local member sending me the missing parts ...
It is unusual for the 1954 Chevrolet Truck Shop Manual to be incorrect in listing Two Springs ( E ) Sec. 12 Page 38 Fig. 56 in their description...
Bill:
Well, I must disagree on two points: 1. The original nuts on my 52 are not plastic and not ferrous metal. 2. Aluminum with steel fasteners is a common occurrence on modern vehicles without problems associated with dissimilar metals.
I do agree that I stated the incorrect supplier had the information wrong in the catalog.
DavidF #785177 10/01/2011 3:42 AM
The original nuts were die cast (zinc alloy), here is a picture of the in an
original headlight assembly. You can clearly see the parting line for the mold:
http://www.pbase.com/dennygraham/image/137400010/original
Here’s a drawing of the original nuts which you can make from aluminum:
http://www.pbase.com/dennygraham/image/138413149
And here they are with all that nasty red paint removed:
http://www.pbase.com/dennygraham/image/138464596
DG
Denny G
Sandwich, IL
