12 members (Charles in CA, MickeyP, GIJOE298, joe apple, Jon G, Ribside, 3B, Bill Hanlon, lumbersawyer, 55shaker, dt235sd, 1 invisible),
97
Mod | | | Forums66 Topics128,134 Posts1,056,738 Members48,454 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2010 Posts: 114 Shop Shark | | Shop Shark Joined: Apr 2010 Posts: 114 | so when i picked up my 51 in 1993 it came with new tie rod ends of the original style that were purchased around 1987 or 88. thought they were lost all these years but just found them in an old tool box. Are these still safe to use on my restoration or should i use the new style they sell now? | | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | Sure, if they are new as you say. They're perfectly safe to use, if they are in good condition after all millions of these trucks have been running around for 50, 60, 70 years using these tie rod ends. The only time you ever hear of a problem is when the maintainance hasn't been keep up. Guys switch to the newer style because they require less up keep and they give you the little extra clearance needed when installing later style rims. Denny Graham Sandwich, IL
Denny G Sandwich, IL
| | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | Ditto to Danny's response.
They are safe.
Also in agreement with Denny about good maintenance. You might want to take apart the ends and make sure that the ball-joint is round and not oval.
The original-style tie-rod ends (with the ball joints/stud) are still available from rareparts.com; and, rebuild kits are also still available from many vendors.
| | | | | Joined: Apr 2010 Posts: 114 Shop Shark | | Shop Shark Joined: Apr 2010 Posts: 114 | | | |
