3 members (TexasA&M48Truck, Bill Hanlon, 52Carl), 94 guests, and 2 robots.
Topics128,094
Posts1,056,058
Members48,433
#783467 09/25/2011 3:42 AM
I'm almost ready to fire up my newly rebuilt 261 and want to confirm the oil capacity....from what i could find it states 7 quarts. Does this sound accurate? I do have the canister w/ filter. thumbs_up
According to the manuals, it's 6 quarts with filter.
Bill Burmeister
7 quarts is what I poured in to my late 261. A 1960 version.
Drew
DrewP #783553 09/25/2011 4:21 PM
1960 shop manual also states 6 quarts for the 261.
Bill Burmeister
In 1960, the C60 Jobmaster was a 261 engine. The Owner's Manual indicates 7 qts of oil - 5 for crankcase a 2 for oil filer.
When my 1960 261 used the beautiful, original, full-flow canister oil filter, it required 7 qts of oil.
Intersting. The shop manual only lists the 1 quart filter for the 261. I also have a 261 oil filter on my 235 that came from a '60, it only holds 1 quart as well. Looks like there's an option, you're going to need to verify which filter you have.
BTW, yes, I'm still kicking myself for not getting the rest of that 261. Meant to go back and get it, but the yard finally cleared out all the vintage stuff earlier this year.
Bill Burmeister
thanks for info guys...i'll try 6, check and recheck and go from there. Thanks for the tip on which filter as this would make a big difference. thumbs_up
