3 members (RLB, Oswald, GRNHydra), 86 guests, and 2 robots.
Topics128,030
Posts1,055,430
Members48,422
#782923 09/22/2011 10:54 PM
Hello All -
Just hooked up my temperature sender to my idiot light on dash. When I start the truck, nothing happens. But then as time passes...seconds, not minutes...the light glows brighter and brighter. Does my thermostat need replacing? Your thoughts?
Thanks much!!!
Thom Masterson
Sir Searchalot
Sir Searchalot
Can't heat up in seconds. bad sensor, wiring, idiot light or sensor not grounded. If you use too much thread sealer you will not get ground. You can hook up a ohm meter and put sensor in hot water heated gradually. 200+ ohm change from cool to hot. Does your truck show any signs of being hot? Don't think the water is getting hot (165-180) that fast. Also if you just got a new sender, you may have been given one for a gauge not a light.
The light should be green when started up, indicating cold temp. Will turn red if overheats.
http://s971.photobucket.com/albums/ae197/jon63c10
1963 c-10 shortbed stepside 427 BBC T16 HD 3 speed
1963 c-10 shortbed fleetside 348 "w" 1st gen big block & powerglide
Riding in the Passing Lane
You probably have the wromg sender unit. You need one for a light. If you have the green light also like Jon mentioned it takes a sender with 2 terms.
1972 Chevy c10 Cheyenne Super
I think you guys are right. I probably have a sender for a gauge...not a light. The bulb slowly grows brighter eventhough the water is not that hot and stays on. I did not know there were two different types of units. I think I bought that sender from LMC. Anyone know where to get one for idiot lights?
Thom Masterson
Any parts store can get it for you. Their catalog breaks it down into with gauge & with light.
It might have 2 terms. Likesomeone said some use a green lite when cold. If you have one like that & the red light comes on with the engine cold use the other term.
Sir Searchalot
Sir Searchalot
Don't be an "Idiot", Get a gauge.
Finally had time to do something this weekend. Got the correct sender in and the lights work great. Thanks for the information!
Thom Masterson
I
I Offline
I have a virtually original '62 Stepside, 235 with 3 on the tree, that I found in central Oregon with only 70k miles on it. We have gone through it from end to end and have repaired, overhauled or replaced everything necessary to make it safely operational. I have only one problem. This truck came with the "idiot light" dashboard; everthing works except the temperature gauge. The reason it doesn't work is the sending unit...my cylinder head is drilled and tapped for a 9/16" sending unit with an "L" shaped, two pronged plug...the wiring loom is original and has the correct plug on it. The only sending unit I have been able to find is a 3/4" threaded unit with the correct prong arrangement. Any ideas out there?
'62 Chevy C10 Short Bed Step Side, 235 Six with Offy intake, 2 carter/weber 2bbls and Fenton headers. B-W T5 5 speed trans, with stock rear end.
Could probably go to the hardware store and fix it with some brass fittings.
My experience is that you have the correct sender. I wonder if the head/engine was exchanged at some point for one that has the hole for the gauge sender, whcih is smaller? I know they sell reducing bushings so you can fit a guage sender in a light hole. There isn't one in there now? Aside fron that, I would think you have ot change the head, or drill a bigger hole (scary). Or a bunch of pipe fittings which would locate the sender up in the air somewhere. may look funny, but should work.
