| | | Forums66 Topics128,052 Posts1,055,774 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#78334 06/02/2007 8:03 PM | Joined: Apr 2004 Posts: 375 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2004 Posts: 375 | It's been awhile since we talked about my truck. You may recall all the trouble I've had with carburetion and other things on the ole girl. It's a '62 235 punched .030 over with stock cam and professionally built by a local speed shop. I have an Offy dual intake with Carter/Weber 2bbls on it with Fentons and Flowmaster 40's. She's got HEI and alternator. All of the wiring is new. It's timed to stock specifications (on the dot).
Generally, she runs very well. It seems to bog just a little ok take-off or when I try to do a rapid acceleration. I suppose it's possible that I need to work on carburetor adjustment or synchronization but I can't help but wonder if it needs to be timed differently.
I punched a hole in a piston once because the timing and air mixture were off so I'm a bit punchy about just turning the distributor until it runs.
What are your thoughts on timing? My challenge? | | |
#78335 06/02/2007 8:34 PM | Joined: Jul 2004 Posts: 5,708 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 5,708 | Jerry A,
I think experimenting with the timing is a very good first step. Detonation can surely blast a piston to pieces, but it seems you would have heard pinging and knocking long before it got serious enough to do this. The lean fuel/air mixture would only have adverse effects under the most extreme conditions and for a prolonged period of time. I'm certainly not a race engine mechanic, but I think something else might have been responsible for your piston failure, and I wouldn't be hesitant to fiddle with the timing all you want. The engine will tell you when it doesn't like what you have done...long before it will commit seppuku .
Stuart | | |
#78336 06/02/2007 8:56 PM | Joined: Apr 2004 Posts: 375 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2004 Posts: 375 | The piston looked like a 22 round went through it. I had driven it at highway speeds for about 300 miles. | | |
#78337 06/02/2007 10:34 PM | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | I would boost the timing up a few degrees . Those specks are for the gas they had back then. While that old leaded fuel was better, we have more octane now. It can handle more timing. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | |
#78338 06/03/2007 2:02 AM | Joined: Apr 2004 Posts: 375 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2004 Posts: 375 | Ok; here's dumba.. question of the day. Is 'to advance' a clockwise move of the distributor? | | |
#78339 06/03/2007 2:29 AM | Joined: Jul 2004 Posts: 5,708 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 5,708 | Jerry A,
The rotation of the distributor is clockwise. If you want the plug to fire earlier..advanced..you rotate the distributor against the direction of rotation..counter-clockwise. No dumba questions on this site!
Stuart | | |
