5 members (greenie-reddy, frogfarmer, Gray_Ghost, 2 invisible), 319 guests, and 5 robots.
Topics128,156
Posts1,057,019
Members48,460
#783305 09/24/2011 5:54 AM
On my 59, 235 I have a copper tube running from the right side of the head to the inlet of the oil filter. Is this the correct way to feed oil to the rockers. I have been looking at other 235s and I see a that the hole on the head is pluged, is it getting oil feed from some other source?
Thanks Larry
there is an internal tube for this oiling (you can see it if you pull the lifter cover) which often clogs. in the past a kit to re-route the oil tube externally was offered and this is likely what you have. my '56 235 has the same set-up. tom
It's not uncommon for the internal passages to get clogged. Back when there were a lot of these engines on the road, we would remove the head bolt adjacent to that plug in the head, pour the hole full of oil, and use a snug fitting dowel rod and a big hammer to clear the passageway. It's possible to blast a high-pressure pulse of oil down the galleries by smacking the dowel a few times with a BFH. If that didn't clear the problem, we would install the external bypass line.
