4 members (dt235sd, 3100RustyParts, 54farmtruck, TUTS 59), 75 guests, and 2 robots.
Topics128,213
Posts1,057,488
Members48,473
I noticed today the the front axle is badly bent upwards on the passenger side of my 49 3800 one ton truck. My truck is now a flatbed , but it came from the factory with a 9ft pickup bed, so it is NOT a dually. I know that there are axle shops that can straighten this out at a big expense, but I'm wondering if a 3/4 ton axle would be the same. Instead of fixing mine, I would rather just swap it out.
The aviation artist guy in Houston that loves old trucks even more than planes. www.jasonbarnettartist.com
There are a couple of 1 Ton axles on Ebay right now.
1951 1 Ton Completed
I'm thinking a machine shop should be able to press it straight again.
Here is a link to some stuff about my brothers and I
http://bus-plunge.blogspot.com/search?q=hemmings
shops working on big truck front ends could straighten it. I believe the 3/4 ton axle is the same. the brakes are larger on the 1 ton
Robert French MY3800FIRETRUCK
There is a shop here locally that straightens 18 wheeler axles that I could try. I think I am still going to try and find a 1953 or so 3800 axle to get the better brakes off of.
