| | | Forums66 Topics128,009 Posts1,055,297 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2001 Posts: 1,096 'Bolter | | 'Bolter Joined: Feb 2001 Posts: 1,096 | Hi guys ,, I have a '55 diff apart at the moment ,, I want / need to replace the carrier bearings . The local bearing house cannot get the original style barrel roller bearings , and wants to sell me taper roller bearings as a replacement . Is this going to be a good thing , or should I try to source the proper style from the USA ? What are your thoughts on this please . | | | | | Joined: Feb 2001 Posts: 1,897 Member | | Member Joined: Feb 2001 Posts: 1,897 | Big trucks use tapered roller bearings  I would use them unless you want to remain original.
| | | | | Joined: Feb 2001 Posts: 1,096 'Bolter | | 'Bolter Joined: Feb 2001 Posts: 1,096 | Thanks for your thoughts Luke ,, I wasn't so much worried about originality as having the correct part , for long life in service .  | | |
