| | | Forums66 Topics128,141 Posts1,056,779 Members48,454 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2011 Posts: 205 Shop Shark | | Shop Shark Joined: Sep 2011 Posts: 205 | Hi..I'm the new bolter...and just aquired the 6 suburban that was on Ebay yesterday...excited aobut starting this long project. How much wood is really in this suburban's main body..especially the rear where those doors are ? I don't have it in the flesh yet..but will in tow weeks. Then the fun begins. Body is rough but will all work out with patience. It;s the wood pieces that scare me a bit. thanks for any help...Bruce D. | | | | | Joined: Oct 2004 Posts: 1,780 Master Gabster | | Master Gabster Joined: Oct 2004 Posts: 1,780 | You were quick to find the 'bolt! Nice score!  The wood should not be too bad to make, most of it is looks to be in decent condition and at least good enough for patterns. You may want to consider using tube steel when replacing the wood. It will hold up better, last longer and will not be seen. If you insist on using wood, find someone that does the wood for Model A's or woody wagons. It won't be cheap, but it should be doable. Contact Ron Brazell he once owned this one! . | | | | | Joined: Dec 2005 Posts: 2,557 'Bolter | | 'Bolter Joined: Dec 2005 Posts: 2,557 | That's going to be one awesome project.It's hard to believe the rear seats are still their.
Tim 1951 3100 Chevrolet1951 Chevrolet Suburban CarryallImage"A house is built with boards and beams. A home is built with love and dreams." "Look deep before you leap !!!" / "Everything is Everything" "If I say a mouse can pull a house, hitch him up"
| | | | | Joined: Oct 2004 Posts: 1,780 Master Gabster | | Master Gabster Joined: Oct 2004 Posts: 1,780 | Bowtietim posted this in another post: KC WOOD MANUFACTURER Specializes in Early Chevy Wood. Give him a call or email him. | | | | | Joined: Sep 2011 Posts: 205 Shop Shark | | Shop Shark Joined: Sep 2011 Posts: 205 | thanks a lot tim.... I have sent them an email..bruce d. | | | | | Joined: Sep 2011 Posts: 205 Shop Shark | | Shop Shark Joined: Sep 2011 Posts: 205 | thanks a lot..I will call them..they helped me with my colors for my 36 pickup..we did it in Hollywood tan, same color that the suburban offered also. bruce | | | | | Joined: Oct 2002 Posts: 52 'Bolter | | 'Bolter Joined: Oct 2002 Posts: 52 | Bruce
There is A LOT of wood in the body. I helped a few guys out with patterns for the rear clam shell door a few years back with photos / dimensions from my '36 suburban.
If you need any running gear / suspension parts - I just sold mine to a street rodder who had no interest in axles, springs, steering column, engine, transmission, pedal assembly, etc.
I have a good running 206 as well if you want to keep it stock.
My burb is headed to Pensacola Florida - will probably pass yours on the freeway somewhere.
I have good shipping connections and could get you all these parts to Idaho pretty easily.
Ken Brown Vancouver, WA
Life's short - don't waste it.
| | | | | Joined: Sep 2011 Posts: 205 Shop Shark | | Shop Shark Joined: Sep 2011 Posts: 205 | Ken thank you so much. I don't have it yet..so I don't what is needed. I know that it has been sored in the guy's two garages fo 46 years! I can only guess that it needs everything you mentioned..so PLEASE keep me in mind. My cell# is 208 610 4501. I have a real good boat builder woodworker pal..but have no idea what will be needed. One of the bolters wrote that tube steel might be a better answer than the wood..(where it isn't seen.) Any thoughts? All seats are there thank God. Engine wise..will nkow in two weks..cross your fingers! ha! Thanks agian for your advice...Bruce D. Sandpoint Id. | | | | | Joined: Nov 2009 Posts: 20 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2009 Posts: 20 | I passed your question on to a similar 'burb owner in Detroit and he wanted to make sure I introduced you to the name of David Entler of PA. His work is very highly thought of and he has done complete wood packages for both Suburbans and Panels. David sent me some very impressive photos of his work as I was looking for a package for my '36 one and one-half ton. If you PM me, I can provide you with more contact information and copies of his photos. | | | | | Joined: Oct 2002 Posts: 52 'Bolter | | 'Bolter Joined: Oct 2002 Posts: 52 | I am pretty sure it was David Entler that I sent dimensions / photos to to complete the rear gate kit he was making for a '36 suburban - I believe that the kit cost upwards of $5k.
David J Entler Restorations Glen Rock Pa. 717.235.2112.
| | | | | Joined: Sep 2011 Posts: 205 Shop Shark | | Shop Shark Joined: Sep 2011 Posts: 205 | Is there Wood under the body of the 36 Suburban for supports? thanks..Bruce D. | | | | | Joined: Sep 2011 Posts: 205 Shop Shark | | Shop Shark Joined: Sep 2011 Posts: 205 | 5,000 for just for the tailgate kit? Thats rediculous! In this poor economy..he won't be getting my business. Bruce | | | | | Joined: Sep 2011 Posts: 205 Shop Shark | | Shop Shark Joined: Sep 2011 Posts: 205 | I talked with David E...and what a great help with inf on rust removel..the kit for whole suburban is about five G's ..mis read that I guess...no kit for tialgate..hope mine is in decent shape. Door kits are about 500. per door. Thanks for the help on this wood project. Bruce | | | | | Joined: Mar 2011 Posts: 457 Shop Shark | | Shop Shark Joined: Mar 2011 Posts: 457 | Just saw this. That is a rare truck...Great Find! Lot's of work ahead, but it will be worth it. Post some pics when you get it home!
1940 Chevy 1/2 ton pickup "KC" A day without sunshine is like, well, ..... dark! | | | | | Joined: Oct 2002 Posts: 52 'Bolter | | 'Bolter Joined: Oct 2002 Posts: 52 | A 36 would have 100 percent steel doors. Cowl and door surrounding frames are wood framed similar to a 35.
| | | | | Joined: Apr 2005 Posts: 177 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 177 | i got kens suburban it should be here thursday i am going to take all the wood out and replace with metal. after i make my patterns if the wood is solid i will have no need for it. | | | | | Joined: Sep 2011 Posts: 205 Shop Shark | | Shop Shark Joined: Sep 2011 Posts: 205 | thank you..just sent you an email...wood may be fair to...? been setting inside a long long time..we'll see....my address is Bruce Duykers 41 pine ridge road Sandpoint Idaho.83864 | | | | | Joined: Oct 2004 Posts: 1,780 Master Gabster | | Master Gabster Joined: Oct 2004 Posts: 1,780 | Interesting progression of information. If I remember right, Ken's suburban came from Idaho and now resides in Florida and the wood may come back to Idaho in another project! Lot's of collaboration on putting these projects back together too!  | | | | | Joined: Apr 2005 Posts: 177 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 177 | my wife wants me to stop working on my 35 truck and start on the suburban when it gets here she thinks i bought it for her to drive she said she will help finance it[ life is good here] | | | | | Joined: Nov 2009 Posts: 20 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2009 Posts: 20 | Here are some photos of what the wood looks like. A couple of hours on a Sunday afternoon and you'll be ready for business! 1935 Burb , Wood Photo 1 , Wood Photo 2 , and Wood Photo 3 . Enjoy | | | | | Joined: Oct 2002 Posts: 52 'Bolter | | 'Bolter Joined: Oct 2002 Posts: 52 | my wife wants me to stop working on my 35 truck and start on the suburban when it gets here she thinks i bought it for her to drive she said she will help finance it[ life is good here] Hi Leonard - sounds like you have married well - my wife has been supportive of my habit for rust, but she has had enough of projects that don't make progress. After seeing what an ordeal that Old Sub's wife went through when he died this last winter, I decided it was time to start selling. I hope you have a good way to get the skid off of your trailer - it was a challenge for me to load at my home. Ken Brown
| | | | | Joined: Sep 2011 Posts: 205 Shop Shark | | Shop Shark Joined: Sep 2011 Posts: 205 | I was told recently that if 36 wood is in decent shape I could mix an epoxy res then thin it slightly and paint each wood part making it solid and hard as new..(pieces not seen of course) Window frames look good so hope the rest of it is not rotted. | | | | | Joined: Jul 2001 Posts: 3,887 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Jul 2001 Posts: 3,887 | Bruce - do some searching and reading on "wood epoxy saturation technique" [WEST system], it's a common wooden boat preservation/repair method, might find a shop in your area that can supply the right materials
Bill | | | | | Joined: Sep 2011 Posts: 205 Shop Shark | | Shop Shark Joined: Sep 2011 Posts: 205 | Well..not quite...no wood from Ken's to my project..but may get some artillerys and motr, or some drive train stuff..won't know till mine gets here fri. Small world when it comes to restoring old rare classics! | | |
