1 members (1 invisible),
65
0
Mod | | | Forums66 Topics128,049 Posts1,055,740 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2011 Posts: 33 New Guy | | New Guy Joined: May 2011 Posts: 33 | where do i find one in wi. thanks | | | | | Joined: Nov 2001 Posts: 1,517 'Bolter | | 'Bolter Joined: Nov 2001 Posts: 1,517 | Pretty much any place that cuts keys.
| | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | Should take the B10 blank, still readily available in the aftermarket, as Marty stated, anyone that cuts keys should have them. OEM Briggs & Stratton B10s are also available from several vendors and Ebay as repop and NOS items relativley cheap, if you want an OEM key. If you don't have a key at all, any locksmith can make you one. Just take them the lock cylinder from the ignition switch.
Bill Burmeister | | | | | Joined: May 2011 Posts: 33 New Guy | | New Guy Joined: May 2011 Posts: 33 | thanks, i do have truck running yet 21gs
thanks, i do not have truck running yet. 21GSI-4968. what length is a long box. i think i am third owner. i also have to get a title. i have not work on the truck since 6/7/11. i hope to be working on it soon
