5 members (Otto Skorzeny, 2-Ton, TexasJim50, MickeyP, MRMEROTH11), 117 guests, and 3 robots.
Topics128,132
Posts1,056,383
Members48,441
#782597 09/21/2011 9:49 PM
Hi My truck is a 1937 Chev 1/2 ton Right hand drive (engine cast in Canada)
Getting ready to start the engine but noticed a kink in the small copper oil line from oil pump back to the block (located on the carb side of the engine) so I though no problem I will replace that section.
After loosening conections coolant leaked out of block -
Question - is the oil line one piece from oil pump to rockers? if so how is this replaced
Denis
The line is a 1-piece setup from the oil distributor near the exhaust pipe to the valve lifter area on the opposite side of the block. It goes through the water jacket on the way, so it must be sealed. The fittings in the block the line goes through have compression-type ferrules that are one-time use items. If you want to replace the line, most of the antique parts distributors have a kit available that includes a line the right size and the necessary fittings to do the job. You only get one chance to do it right.
There was a post a while back where someone made their own version of this line. I believe they used a male pipe thread fitting that transitioned to a compression fitting. They drilled out the middle so the tube could pass through.
1951 1 Ton Completed
Thanks Hotrod -
I suggested that fix, along with using a piece of 3/16" steel brake line since the original-equipnment 3/16" copper line is almost impossible to find. The steel line is a little tricky to bend without collapsing it, but otherwise, it's a pretty simple fix.
Ex Hall Monitor
Ex Hall Monitor
