| | | Forums66 Topics128,091 Posts1,056,036 Members48,433 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2006 Posts: 693 'Bolter | | 'Bolter Joined: Jun 2006 Posts: 693 | any ideas on how to get light paint overspray off upholstery without marring the vinyl? | | | | | Joined: Jun 2009 Posts: 2,201 Shop Shark | | Shop Shark Joined: Jun 2009 Posts: 2,201 | Is it fairly new paint? Dish soap and water might work if it is. | | | | | Joined: Jun 2006 Posts: 693 'Bolter | | 'Bolter Joined: Jun 2006 Posts: 693 | i'm afraid its not too fresh - but i'll give it a whirl.. thanks | | | | | Joined: May 2010 Posts: 85 New Guy | | New Guy Joined: May 2010 Posts: 85 | Goo gone? That may be the least aggressive....every other recommendation I have would be much more aggressive... Alcohol acetone etc. Whatever you do, dab it, don't rub it. And try in an inconspicuous area first.
Do something! Even if it's wrong!
| | | | | Joined: Jun 2006 Posts: 693 'Bolter | | 'Bolter Joined: Jun 2006 Posts: 693 | i have some goo gone, so i'll try that next. soap and water didn't work. thanks! | | | | | Joined: Jun 2008 Posts: 1,388 Shop Shark | | Shop Shark Joined: Jun 2008 Posts: 1,388 | How about Bon Ami, hasn't scratched yet! | | | | | Joined: Nov 2001 Posts: 275 Shop Shark | | Shop Shark Joined: Nov 2001 Posts: 275 | Sorry this is so late. Have you tried soapy water and clay (the kind you use pryor to waxing)? It works on plastic eye glass lenses splattered with overspray. | | | | | Joined: Jun 2006 Posts: 693 'Bolter | | 'Bolter Joined: Jun 2006 Posts: 693 | thanks for your reply. i will give the clay bar a try as i have the same issue to a smaller extent on one of the vinyl door panels | | |
