8 members (MNSmith, Samantha, cmayna, Phak1, 66flea, Jon G, CATMAN, 1 invisible),
44
Mod | | | Forums66 Topics128,154 Posts1,056,850 Members48,456 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2010 Posts: 170 'Bolter | | 'Bolter Joined: Jun 2010 Posts: 170 | Sorry, dumb question here. I bought single sided foil backed padding several years back, it has no instuctions. I plan to use it on my firewall interior. The foil side goes towards the engine side - with the plain insulation towards the interior correct? | | | | | Joined: Aug 2005 Posts: 6,377 Ex Hall Monitor | | Ex Hall Monitor Joined: Aug 2005 Posts: 6,377 | That's the way I would do it. I'm not an expert by any definition but foil is used in other applications to reflect heat back so putting it on the hot side makes sense to me.
| | | | | Joined: Sep 2003 Posts: 1,820 Shop Shark | | Shop Shark Joined: Sep 2003 Posts: 1,820 | That's a darn good question and I am not saying you are wrong,Tiny ! I may well be wrong in my thinking. I know that when decking a house for a roof, the foil goes on the underside and not toward the heat source, that being the sun. I also know that one of things that is done if a house does not need a roof is the hang foil in the attic under the rafters. So not trying to muddy the water here, but I have often wondered the answer. I am about to order some foil on one side insulation for my cab, too, and would like a definitive answer. The heat from the engine compartment is pretty intense.
"Truckin' Around .......... Since 1937!" My name is Joe and I am addicted to Classic Country Music. I just can't hep myself.Operators are standing by to take your calls! Now cruising in the Passing Lane | | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | Foil-side (or other vapor barrier-side) on house insulation usually goes on the inside-of-the-house side. However, that rule changes depending on which air mass is the most likely to condense and which side you provide vapor escape (dependent on the climate in which you live).
In a car/truck, the foil side probably serves a different purpose than it would in a house. I'd look for single-sided padding of similar construction and see what the manufacturer suggests when used in a vehicle.
| | | | | Joined: Mar 2005 Posts: 31 Wrench Fetcher | | Wrench Fetcher Joined: Mar 2005 Posts: 31 | Ok i used heat shield & sound deadener. part no. 25070 & the instructions say installing in engine compartmeat & floor boards aluminum foil is always towards heat. Any other applications, the aluminumfoul faces out. | | | | | Joined: Sep 2003 Posts: 1,820 Shop Shark | | Shop Shark Joined: Sep 2003 Posts: 1,820 | Foil-side (or other vapor barrier-side) on house insulation usually goes on the inside-of-the-house side. However, that rule changes depending on which air mass is the most likely to condense and which side you provide vapor escape (dependent on the climate in which you live).
In a car/truck, the foil side probably serves a different purpose than it would in a house. I'd look for single-sided padding of similar construction and see what the manufacturer suggests when used in a vehicle. Thanks, Tim. I should know better than to compare anything in a house to anything in a car! Joe
"Truckin' Around .......... Since 1937!" My name is Joe and I am addicted to Classic Country Music. I just can't hep myself.Operators are standing by to take your calls! Now cruising in the Passing Lane | | | | | Joined: Oct 2009 Posts: 201 Shop Shark | | Shop Shark Joined: Oct 2009 Posts: 201 | Thermodynamics don't know where they are being applied - car, house, spacecraft, etc.
The foil goes to the air space side. If there is no air it does not prevent radiant heat transfer. In your case, there is not really an air space but I'd go ahead and put the foil toward the cab. Against the firewall it has zero chance of blocking heat, against the carpet pad or carpet back, at least there is some limited air space for it to function as designed.
Tclederman, in a house the foil side of radiant barrier plywood goes to the attic when used on a roof deck, and towards the outside when used on walls. Both cases provide an air gap at the foil to allow it to work. I've never seen foil facing on insulation unless you're referring to XPS rigid foam sheathing in which case again the foil faces out. But you're in NY and I'm in TX, and as you said, different climates use different methods, either way, the physics are the same.
'69 1/2T stepside, Sea Foam Green, 250 L6 w/ 3 on the tree, not an option on it, in the family since new.
| | | | | Joined: Mar 2006 Posts: 37 Wrench Fetcher | | Wrench Fetcher Joined: Mar 2006 Posts: 37 | maybe look up and contact seller/supplier and ask? | | | | | Joined: Jun 2010 Posts: 170 'Bolter | | 'Bolter Joined: Jun 2010 Posts: 170 | Thanks everyone for the replies. Depending if I have enough I'll double it up on itself, half foil in, and half foil out. Otherwise I think I'll try the foil side to the inside. I had a 48 dodge sedan that was always too hot inside, I used it on that with the foil towards the firewall and didn't notice much difference. It may be I just have the "el cheapo" product. Thanks again. | | |
