| | | Forums66 Topics128,076 Posts1,055,920 Members48,429 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2011 Posts: 59 Wrench Fetcher | | Wrench Fetcher Joined: Feb 2011 Posts: 59 | I am mounting my heater back in my 59 Apache and I can not remember how the support bracket attaches to the bottom of the dash.I have looked in the manual but see nothing on heaters. Please look at the photo. Thanks Larry | | | | | Joined: Jul 2001 Posts: 3,887 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Jul 2001 Posts: 3,887 | look at what photo?  heaters are in the accessory manual depends on what heater you have, standard [recirculating] or deluxe or basic dealer model .... I don't recall a support that attaches to the dash on any of the 3, but maybe something in here might help - the heaters all mount to the firewall with long bolts and standoffs, maybe the 'support' you have is for a radio? Bill | | | | | Joined: Feb 2011 Posts: 59 Wrench Fetcher | | Wrench Fetcher Joined: Feb 2011 Posts: 59 | | | | | | Joined: Feb 2011 Posts: 59 Wrench Fetcher | | Wrench Fetcher Joined: Feb 2011 Posts: 59 | Thanks Bill I see the bracket on the very left of one of your photos but can not see how it is attached. Larry | | | | | Joined: Jul 2001 Posts: 3,887 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Jul 2001 Posts: 3,887 | you're right, that's the standard version heater, and there is a bracket there - the one in my pic is in my daily driver, I had to go out and look, I just hooked mine over the bottom lip of the dash, there's holes thereabouts but I didn't bolt it
Bill | | | | | Joined: Feb 2011 Posts: 59 Wrench Fetcher | | Wrench Fetcher Joined: Feb 2011 Posts: 59 | I can remember removing the bolt and I have it in my plastic bag, but the holes don't line up. Larry | | | | | Joined: Jul 2001 Posts: 3,887 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Jul 2001 Posts: 3,887 | maybe if you put the bracket above the dash lip, which may pull that plenum back a bit, it would line up?
Bill | | | | | Joined: Feb 2011 Posts: 59 Wrench Fetcher | | Wrench Fetcher Joined: Feb 2011 Posts: 59 | The bracket has a offset bend so it can not come forward enough to reach the hole. It would work if I put some flat washers under the bracket as the lip on the bottom of the dash is much larger. Larry | | |
