0 members (),
93
Mod | | | Forums66 Topics128,167 Posts1,057,021 Members48,458 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#78198 05/29/2007 10:00 PM | Joined: Jul 2005 Posts: 66 Shop Shark | | Shop Shark Joined: Jul 2005 Posts: 66 | I have a fuel leak that I cannot seem to stop. It all started when I rebuilt the carburetor. It leaks from the brass fitting that goes into the top of the carb. I've tried everything and it still leaks. Today, I bought a new fitting and put a different carburetor top on that I had lying around. All factors are different than before and I still have the same darn problem. Could it possibly be that the float is set wrong or something. HELP!! (It's a Rochester 1 barrel on a 235 straight six). | | |
#78199 05/29/2007 10:26 PM | Joined: Aug 2002 Posts: 455 Shop Shark | | Shop Shark Joined: Aug 2002 Posts: 455 | Try using a small amount of JB weld or Loctite weld, available in the local car parts stores. These are 2-part epoxy.
This will seal any leaks on the brass fitting into the carb and last practically forever. Carful not to use too much! Just enough to coat the threads and don't overtighten.
Let it cure overnight before connecting it to fuel. | | |
#78200 05/29/2007 10:42 PM | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | If the leak is where the fuel lone goes into the fitting you may have cracked flare or it is scored & won,t seat. You may have to cut it off & reflare the tube. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | |
#78201 05/29/2007 11:43 PM | Joined: Nov 2002 Posts: 2,767 Carburetion specialist | | Carburetion specialist Joined: Nov 2002 Posts: 2,767 | Before you can fix the problem, you must identify the problem.
Take a paper towel and dry everything. Then have a friend bump the starter until the leak starts. Possible leaks:
Split airhorn casting Defective airhorn thread Defective fitting Wrong fitting Missing gasket (if used) Defective flare on fuel line
Determine which of the above is the culprit, and repair. If all parts are good, no sealer of any type is necessary.
Based on your posts, my guess is that Wrenchbender is correct in his diagnosis.
Jon. Good carburetion is fuelish hot airThe most expensive carburetor is the wrong one you attempt to modify. If you truly believe "one size fits all," try walking a mile in your spouse's shoes!The Carburetor Shop | | |
#78202 05/30/2007 12:04 PM | Joined: Jul 2005 Posts: 66 Shop Shark | | Shop Shark Joined: Jul 2005 Posts: 66 | It's not a flare fitting. It's a brass nipple, then it has 5/16" fuel line connecting it to the fuel. Someone cut the original fuel filter and line out and put a plastic inline filter in. It makes no sense that it leaks. I did dry everything off and I can see the fuel coming right out of the threads. Like I said, it's a brand new fitting too. I just don't get it. Can there somehow be too much pressure at the carb from the fuel pump? | | |
#78203 05/30/2007 12:54 PM | Joined: Nov 2002 Posts: 2,767 Carburetion specialist | | Carburetion specialist Joined: Nov 2002 Posts: 2,767 | Allow me to rephrase to see if I understand:
The original line has been modified to accept an inline fitting, with neopreme hose connecting the line to the inline filter and the inline filter to the fuel fitting on the carburetor?
If this is correct, then:
(A) Check to make sure brass fitting is correct thread both in type and pitch for airhorn.
(B) Unless the thread in both is tapered thread (pipe) then a gasket would be required to seat the fitting to the airhorn.
(C) Four hose clamps would be required (2 on each connector hose).
