1 members (Bucker),
144
Mod | | | Forums66 Topics128,196 Posts1,057,391 Members48,471 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2006 Posts: 40 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2006 Posts: 40 | I have a 49 Chevrolet 3800 with the 17" 8 lug wheels. I want to convert the front brakes to disc, but I'm hoping one or more of you have already done this and know where to start. Does any one have any idea as to what to do? I'm keeping the stock suspension. I just want to add disc brakes. | | | | | Joined: Mar 2008 Posts: 3,750 'Bolter | | 'Bolter Joined: Mar 2008 Posts: 3,750 | Jason,I'm more clued up the smaller trucks but I think this link might help. There's a fair bit of reading but hopefully it might help you. Good luck! 1950 Chevy Advance Design 3100 in ScotlandIn the Stovebolt GalleryMore pix on Flickr. I've definately got this truck thing in my blood ... my DNA sequence has torque settings"Of all the small nations of this earth,perhaps only the ancient Greeks surpass the Scots in their contribution to mankind" Winston Churchill.
| | | | | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | Yep, that link is what I know so far about adapting disc to a 1 ton.
Realize that there is more than one way to skin a cat, so if you come up with something else let us know!
Grigg | | | | | Joined: Oct 2006 Posts: 40 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2006 Posts: 40 | That method sounds great if i had a heavy dually, but my truck is a fairly light duty single rear wheel ruck. I'm going to start junk yard shopping for a disc brake rotor that I can bolt in place and then maybe make s steel plate to hold the caliper. I would have to find a way to change the bearings out in the hubs to modern type, but I think that would work. Also, those parts from the P30 and HD3500 are a lot of weight to ad to the front of a light duty truck. I know that I had a 1941 Chevy 2 ton truck that I was able to un-rivet the original brake drums from the hub and simply bolted modern Chevy 4 wheel drive 6 bolt discs in place and made a simple bracket to hold the caliper. It worked great. | | | | | Joined: Oct 2006 Posts: 40 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2006 Posts: 40 | That is pretty much what I'm thinking of. The only deal breaker that I can see is the wheel clearance. My truck has the stock 17" wheels, so that probably won't work. There has to be a smaller rotor that would give me wheel clearance. | | | | | Joined: Dec 2011 Posts: 2 New Guy | | New Guy Joined: Dec 2011 Posts: 2 | If you find that out, I would love to know. i am looking into brake upgrades on my 52 3600. | | |
