3 members (TUTS 59, JW51, Jon G), 114 guests, and 4 robots.
Topics128,095
Posts1,056,480
Members48,444
#781259 09/16/2011 3:15 PM
Can anyone tell me what the difference would be between a 1937 1/2-ton (GC) truck clutch pedal and a 1938 and newer? I believe the 37 has a different PN in the master parts book. I am thinking of converting to the newer clutch setup, but just wondering if I will need a different pedal, or can modify what I have.
1959 Chevrolet 3800 Pickup
1937 Chevrolet GC Panel
Can you still call it a barn find if it's your barn?
The 37 link from the pedal to the throw out bearing arm is different in 37 than 38. The 37 used a rod with a nut on it to adjust the clutch and the 38 used a link with a curved rod with two nuts set up to jamb against the throw out bearing arm to adjust it.
You can probably modify the one you have to use the 38 type linkage, but they is a difference between them.
