Labor Day
Labor Day
MORE wrenching?
Wrenching this Labor Day
Plenty of places to share.
7 members (JW51, baldeagle, Dennys28, Bill Hanlon, Peggy M, Maybellene, Southerntruck), 62 guests, and 3 robots.
Topics128,005
Posts1,055,264
Members48,418
#781033 09/15/2011 8:26 PM
Is the stop light switch different on the larger '39-46 1-1/2 Ton Trucks? I am working on a 1940 WB 1-1/2 Ton and it does not have a pressure operated switch on the master cylinder like the pickups. What do they use or has someone changed this truck?
1939 GMC AC-102 Long Bed 1/2-Ton
In the Legacy Stovebolt Gallery
More details in his DITY Bay
1940 Chevy WB Series 1.5-Ton
alkay3 #781048 09/15/2011 9:33 PM
Big Bolt Forum Co-moderator
On an AD it is actuated by the brake pedal. Look on the firewall and see if there is a switch with an arm that gets pushed down by the brake pedal. If there isn't one there, see if there are two small holes for mounting a switch. Someone who knows a lot more than me should be posting soon.
1948 Chevy 2-Ton
alkay3 #781049 09/15/2011 9:37 PM
DR Offline
Check to see if on the firewall under the brake pedal (engine side) if there are to bolt holes. I have a 41 and it uses a swing arm style. It is wired so when the pedal is up, the switch is closed.
DR
