1 members (Hotrod Lincoln),
41
0
Mod | | | Forums66 Topics128,035 Posts1,055,560 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2011 Posts: 24 New Guy | | New Guy Joined: Jul 2011 Posts: 24 | My 216thriftmaster engine (1947) smokes and burn/use/leaks oil by the rate of a quart every 50 miles. It seems to have power, it smokes when I start from a dead stop. I'd like to rebuild myself but lack garage space. How much would a rebuild run (ball park)? Okay what's a guy to do????
wildone | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | Depends on what needs rebuilding: $300-$600 for the head and up to $3,000 for the complete engine (done by someone who knows these engines).
| | | | | Joined: Jun 2008 Posts: 1,388 Shop Shark | | Shop Shark Joined: Jun 2008 Posts: 1,388 | Why not do a compression test, and see where you're at? If you don't drive it too much you could do a get-by engine job. Replace gaskets, check and tighten bearings, Maybe even just re-ring the pistons, hone, and shove them back in.
The 216 in my 1-Ton, uses a quart of oil every 400 miles or so, and has done so for the last 17,000 miles that I've owned the truck. It smokes a bit going down hill.... But oil and the occasional spark plug are pretty cheap! | | | | | Joined: Jul 2011 Posts: 24 New Guy | | New Guy Joined: Jul 2011 Posts: 24 | Thanks I think is some good advice. I also noticed on cooler days it starts like a champ on the first revolution. On a hot day it takes several cranks. Do you have any explainations on that? | | | | | Joined: Jun 2008 Posts: 1,388 Shop Shark | | Shop Shark Joined: Jun 2008 Posts: 1,388 | Is this when the truck is hot? Mine like to have the engine spin a few revolutions before I step on the gas when its hot. I think my carbs percolate a bit when its hot out, and when the truck is hot. | | |
