2 members (VicZ, oldsteve), 123 guests, and 1 robot.
Topics128,087
Posts1,055,974
Members48,430
#780746 09/14/2011 4:37 PM
I am about to put the door glass back in and I am wondering what is the best way to attach the metal regulator tracks to the bottom of the glass? Regular Silicone? Seam Sealer?
Blah, blah, blah, blah . . . and I really mean that.
butyl tape sillycone should be outlawed in the automotive industry.
1953 Chevrolet 3600
Fried Green T'mater (Vern)
Caution: Political Statement
Butyl tape seems like its going to be a royal PITA trying to stuff that and the glass into that slot.
What about the urethane glass adhesive that is used on front and rear glass on most vehicles?
you need the tape for the fit. it will be too sloppy in the channel without it, I tried. pipe clamp with a wood block is the answer.
1953 Chevrolet 3600
Pipe clamp with a wood block??
PLACE THE WOOD BLOCK ON THE TOP OF THE GLASS AND PRESS THE WINDOW WITH TAPE INTO THE CHANNEL WITH A PIPE CLAMP. OOPS Sorry about the all caps I was in working mode for autocad.
1953 Chevrolet 3600
Gotcha . .
Try heating the tape up just a bit to make it more pliable while pushing the glass in place.
Warm to the touch is all it takes. Once it cools it'll grab
that glass real tight
m
