2 members (3B, Cosmo),
149
Mod | | | Forums66 Topics128,080 Posts1,055,951 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2011 Posts: 23 New Guy | | New Guy Joined: Aug 2011 Posts: 23 | I am about to put the door glass back in and I am wondering what is the best way to attach the metal regulator tracks to the bottom of the glass? Regular Silicone? Seam Sealer?
Blah, blah, blah, blah . . . and I really mean that.
| | | | | Joined: Jun 2009 Posts: 2,201 Shop Shark | | Shop Shark Joined: Jun 2009 Posts: 2,201 | butyl tape sillycone should be outlawed in the automotive industry. | | | | | Joined: Aug 2011 Posts: 23 New Guy | | New Guy Joined: Aug 2011 Posts: 23 | Butyl tape seems like its going to be a royal PITA trying to stuff that and the glass into that slot.
| | | | | Joined: Aug 2011 Posts: 23 New Guy | | New Guy Joined: Aug 2011 Posts: 23 | What about the urethane glass adhesive that is used on front and rear glass on most vehicles?
| | | | | Joined: Jun 2009 Posts: 2,201 Shop Shark | | Shop Shark Joined: Jun 2009 Posts: 2,201 | you need the tape for the fit. it will be too sloppy in the channel without it, I tried. pipe clamp with a wood block is the answer.
| | | | | Joined: Aug 2011 Posts: 23 New Guy | | New Guy Joined: Aug 2011 Posts: 23 | Pipe clamp with a wood block??
| | | | | Joined: Jun 2009 Posts: 2,201 Shop Shark | | Shop Shark Joined: Jun 2009 Posts: 2,201 | PLACE THE WOOD BLOCK ON THE TOP OF THE GLASS AND PRESS THE WINDOW WITH TAPE INTO THE CHANNEL WITH A PIPE CLAMP. OOPS Sorry about the all caps I was in working mode for autocad. | | | | | Joined: Aug 2011 Posts: 23 New Guy | | New Guy Joined: Aug 2011 Posts: 23 |
| | | | | Joined: Jul 2007 Posts: 328 'Bolter | | 'Bolter Joined: Jul 2007 Posts: 328 | Try heating the tape up just a bit to make it more pliable while pushing the glass in place. Warm to the touch is all it takes. Once it cools it'll grab that glass real tight
m
