1 members (Hotrod Lincoln),
72
0
Mod | | | Forums66 Topics128,049 Posts1,055,680 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#78068 05/26/2007 10:37 PM | Joined: May 2006 Posts: 256 Member | | Member Joined: May 2006 Posts: 256 | I tried to do a search here..but had no luck, I picked up a Rochester carb.. On the Bottom the P/N is 7004516-c-19..it also has on top.. Rp Rochester GM ..and also stamped by the Linkage Rochester GM..Will this be a good spare for my 55.. 235 I suppose if I did a little more investigating I could find out...But..I trust you guys more than me..
HURRY UP AND WAIT 55 235 3/4
#78069 05/27/2007 5:53 PM | Joined: Apr 2007 Posts: 20 Member | | Member Joined: Apr 2007 Posts: 20 | | | |
#78070 05/28/2007 2:34 PM | Joined: May 2006 Posts: 256 Member | | Member Joined: May 2006 Posts: 256 | Didnt see anything that matched. Anywere else I can look? M/G
#78071 05/28/2007 2:50 PM | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | You really can,t ID it without the brass tag om top. They are usually gone after a few years. Compare the mounting holes with the ones on your 235. The 216 are narrower. What kind of neck does it have where the air cleaner goes on. Does the inlet line go in the front or on the side with a big nut & filter behind it. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | |
#78072 05/28/2007 3:57 PM | Joined: May 2006 Posts: 256 Member | | Member Joined: May 2006 Posts: 256 | Lets see...You know..I just visited e-bay, and saw 2 of them for sale that matched mine (235) exactly..I am going to see if the Mounting holes match...Its a good match..It is missing the Linkage hook up fpr the choke,you know the Bracket..but other wise, its exact. Not a bad find for 10$
