6 members (Gdads51, J Lucas, Shade Baby, Lightholder's Dad, Otto Skorzeny, rfs56trk), 71 guests, and 1 robot.
Topics128,038
Posts1,055,585
#78068 05/26/2007 10:37 PM
I tried to do a search here..but had no luck, I picked up a Rochester carb.. On the Bottom the P/N is 7004516-c-19..it also has on top.. Rp Rochester GM ..and also stamped by the Linkage Rochester GM..Will this be a good spare for my 55.. 235 I suppose if I did a little more investigating I could find out...But..I trust you guys more than me..
HURRY UP AND WAIT 55 235 3/4
#78069 05/27/2007 5:53 PM
http://www.holisticpage.com/camaro/parts/carb.htm
/www.carburetion.com/quadnumber.htm
http://www.stovebolt.com/bboard/cgi-bin//ultimatebb.cgi
try these links to shed a little light
#78070 05/28/2007 2:34 PM
Didnt see anything that matched. Anywere else I can look? M/G
#78071 05/28/2007 2:50 PM
Riding in the Passing Lane
You really can,t ID it without the brass tag om top. They are usually gone after a few years. Compare the mounting holes with the ones on your 235. The 216 are narrower. What kind of neck does it have where the air cleaner goes on. Does the inlet line go in the front or on the side with a big nut & filter behind it.
1972 Chevy c10 Cheyenne Super
#78072 05/28/2007 3:57 PM
Lets see...You know..I just visited e-bay, and saw 2 of them for sale that matched mine (235) exactly..I am going to see if the Mounting holes match...Its a good match..It is missing the Linkage hook up fpr the choke,you know the Bracket..but other wise, its exact. Not a bad find for 10$
