1 members (Hotrod Lincoln), 97 guests, and 1 robot.
Topics128,080
Posts1,055,953
Members48,430
#78046 05/26/2007 7:08 AM
V
Junior Member
Junior Member
V Offline
OK so I got a H/W kit for my 250 Chevy from Langdon's. Put it on started it up. It idles great, advanced the timing a little to smooth it out. She runs good on the primary but, as soon as the secondary opens it backfires (hard) through the intake. Anybody got any ideas??? Jets??? Intake leak??? I gave up for the night I'll get back on her tomarrow. Any insight would be great THANX.
#78047 05/26/2007 1:50 PM
Not that this is going to be any help, but I've used the H/W on my 235....didn't experience any problems with the secondaries. Was wondering if this backfire was experienced under load or just free-winding? Also, make sure you're tapped into the correct vac port on the carb.
I had a little trouble getting the carb to adaptor bracket to seal up....a bit of a miss-alignment with the slotted adaptor holes. Sure sounds like you might have a lean situation. Would imagine a call to Tom L. might be in order.
He'll bend over backwards to make sure you're a satisfied customer.
Dave
Webshot "Tips and tricks" and "Shoebox" Photo Albums
EXPERIENCE is the best teacher...but it gives the test first...and the lesson afterwards.
"What this generation tolerates...the next will embrace"
#78048 05/26/2007 10:20 PM
V
Junior Member
Junior Member
V Offline
OK so a little bit of time and some propane I figured it out. BAD REBUILD it's suckin' air through the throttle bushing looks like I'll be sending it back. Anyone know of any other type of carbs besides the holley and carter that will fit on the 1bbl to 2bbl adapter???
